SELECT data_key, data_value
FROM xf_data_registry
WHERE data_key IN ('options', 'languages', 'contentTypes', 'codeEventListeners', 'deferredRun', 'simpleCache', 'addOns', 'defaultStyleProperties', 'routeFiltersIn', 'routeFiltersOut', 'routesPublic', 'nodeTypes', 'bannedIps', 'discouragedIps', 'styles', 'displayStyles', 'userBanners', 'smilies', 'bbCode', 'threadPrefixes', 'userTitleLadder', 'reportCounts', 'moderationCounts', 'userModerationCounts', 'notices', 'userFieldsInfo')
Run Time: 0.000905
Select Type | Table | Type | Possible Keys | Key | Key Len | Ref | Rows | Extra |
SIMPLE | xf_data_registry | range | PRIMARY | PRIMARY | 27 | | 26 | Using where |
WHERE data_key IN ('brListenerClasses', 'brBriviumAddOns')
Run Time: 0.000088
SIMPLE | xf_data_registry | range | PRIMARY | PRIMARY | 27 | | 2 | Using where |
SELECT cache_value
FROM xf_permission_combination
WHERE permission_combination_id = ?
Params: 1
Run Time: 0.000115
SIMPLE | xf_permission_combination | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT data_value
WHERE data_key = ?
Params: dark_postrating_ratings
Run Time: 0.000119
SIMPLE | xf_data_registry | const | PRIMARY | PRIMARY | 27 | const | 1 | |
SELECT thread.*
user.gender, user.avatar_date, user.gravatar,
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
'' AS draft_message, NULL AS draft_extra,
privacy.snog_flag_view
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
(user.user_id = thread.user_id)
LEFT JOIN xf_user_privacy AS privacy ON
(privacy.user_id = thread.user_id)
WHERE thread.thread_id = ?
Params: 2618
Run Time: 0.000497
SIMPLE | thread | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | user | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | privacy | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT node.*, forum.*
permission.cache_value AS node_permission_cache,
NULL AS forum_read_date
FROM xf_forum AS forum
INNER JOIN xf_node AS node ON (node.node_id = forum.node_id)
LEFT JOIN xf_permission_cache_content AS permission
ON (permission.permission_combination_id = 1
AND permission.content_type = 'node'
AND permission.content_id = forum.node_id)
WHERE node.node_id = ?
Params: 2
Run Time: 0.000374
SIMPLE | node | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | forum | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | permission | const | PRIMARY | PRIMARY | 35 | const,const,const | 1 | |
SELECT post.*
bb_code_parse_cache.parse_tree AS message_parsed, bb_code_parse_cache.cache_version AS message_cache_version,
user.*, IF(user.username IS NULL, post.username, user.username) AS username,
user_profile.*,
user_privacy.*,
signature_parse_cache.parse_tree AS signature_parsed, bb_code_parse_cache.cache_version AS signature_cache_version,
session_activity.view_date AS last_view_date,
0 AS like_date
,(select sum(count_received) from dark_postrating_count where user_id = post.user_id and rating in (1,14,2,3,4,5)) as positive_rating_count
,(select sum(count_received) from dark_postrating_count where user_id = post.user_id and rating in (7,8,9,10,11,12)) as negative_rating_count
,(select sum(count_received) from dark_postrating_count where user_id = post.user_id and rating in (13)) as neutral_rating_count
pr_cache.rating_cache,
pr2.rating
FROM xf_post AS post
LEFT JOIN xf_bb_code_parse_cache AS bb_code_parse_cache ON
(bb_code_parse_cache.content_type = 'post' AND bb_code_parse_cache.content_id = post.post_id)
(user.user_id = post.user_id)
LEFT JOIN xf_user_profile AS user_profile ON
(user_profile.user_id = post.user_id)
LEFT JOIN xf_user_privacy AS user_privacy ON
(user_privacy.user_id = post.user_id)
LEFT JOIN xf_bb_code_parse_cache AS signature_parse_cache ON
(signature_parse_cache.content_type = 'signature' AND signature_parse_cache.content_id = post.user_id)
LEFT JOIN xf_session_activity AS session_activity ON
(post.user_id > 0 AND session_activity.user_id = post.user_id AND session_activity.unique_key = CAST(post.user_id AS BINARY))
left join dark_postrating_post_cache pr_cache ON (post.post_id = pr_cache.post_id)
left join dark_postrating pr2 on (post.post_id = pr2.post_id and pr2.user_id = 0)
WHERE post.thread_id = ?
AND (post.position >= 0 AND post.position < 25)
AND (post.message_state IN ('visible'))
ORDER BY post.position ASC, post.post_date ASC
Params: 2618
Run Time: 0.001829
PRIMARY | post | ref | thread_id_post_date,thread_id_position | thread_id_post_date | 4 | const | 2 | Using where; Using filesort |
PRIMARY | bb_code_parse_cache | eq_ref | content_type_id | content_type_id | 31 | const,sculptan_base.post.post_id | 1 | Using where |
PRIMARY | user | eq_ref | PRIMARY | PRIMARY | 4 | sculptan_base.post.user_id | 1 | |
PRIMARY | user_profile | eq_ref | PRIMARY | PRIMARY | 4 | sculptan_base.post.user_id | 1 | |
PRIMARY | user_privacy | eq_ref | PRIMARY | PRIMARY | 4 | sculptan_base.post.user_id | 1 | |
PRIMARY | signature_parse_cache | eq_ref | content_type_id | content_type_id | 31 | const,sculptan_base.post.user_id | 1 | Using where |
PRIMARY | session_activity | eq_ref | PRIMARY | PRIMARY | 22 | sculptan_base.post.user_id,func | 1 | Using where |
PRIMARY | pr_cache | eq_ref | PRIMARY | PRIMARY | 4 | sculptan_base.post.post_id | 1 | |
PRIMARY | pr2 | eq_ref | post_id_user_id,post_id_rating,user_id_rating | post_id_user_id | 8 | sculptan_base.post.post_id,const | 1 | |
DEPENDENT SUBQUERY | dark_postrating_count | eq_ref | user_id_rating | user_id_rating | 8 | sculptan_base.post.user_id,const | 1 | |
DEPENDENT SUBQUERY | dark_postrating_count | ref | user_id_rating | user_id_rating | 4 | sculptan_base.post.user_id | 1 | Using index condition |
SELECT attachment.*,
data.filename, data.file_size, data.file_hash, data.file_path, data.width, data.height, data.thumbnail_width, data.thumbnail_height
FROM xf_attachment AS attachment
INNER JOIN xf_attachment_data AS data ON
(data.data_id = attachment.data_id)
WHERE attachment.content_type = ?
AND attachment.content_id IN (39908, 48343)
ORDER BY attachment.content_id, attachment.attach_date
Params: post
Run Time: 0.000477
SIMPLE | attachment | range | content_type_id_date | content_type_id_date | 31 | | 20 | Using index condition |
SIMPLE | data | eq_ref | PRIMARY | PRIMARY | 4 | sculptan_base.attachment.data_id | 1 | |
INSERT DELAYED INTO xf_thread_view
(thread_id)
VALUES
Params: 2618
Run Time: 0.000143
SELECT
post.*
pr2.rating
WHERE post.post_id IN (39908)
Run Time: 0.000538
SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | pr_cache | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | pr2 | const | post_id_user_id,post_id_rating,user_id_rating | post_id_user_id | 8 | const,const | 0 | unique row not found |
AND attachment.content_id IN (39908)
AND (data.filename LIKE '%.png' OR
data.filename LIKE '%.jpg' OR
data.filename LIKE '%.jpeg' OR
data.filename LIKE '%.jpe' OR
data.filename LIKE '%.gif')
GROUP BY attachment.content_id
Params: post
Run Time: 0.000367
SIMPLE | attachment | ref | content_type_id_date | content_type_id_date | 31 | const,const | 10 | Using index condition |
SIMPLE | data | eq_ref | PRIMARY | PRIMARY | 4 | sculptan_base.attachment.data_id | 1 | Using where |
INSERT INTO `xf_session` (`session_id`, `session_data`, `expiry_date`) VALUES (?, ?, ?)
Params: 377977aa2f43a878490dbd7cc4618a5b, , 1714443464
Run Time: 0.000231
INSERT INTO xf_session_activity
(user_id, unique_key, ip, controller_name, controller_action, view_state, params, view_date, robot_key)
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
controller_name = VALUES(controller_name),
controller_action = VALUES(controller_action),
view_state = VALUES(view_state),
params = VALUES(params),
view_date = VALUES(view_date),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=2618, 1714439864,
Run Time: 0.000300
SELECT title, template_compiled
FROM xf_template_compiled
WHERE title IN ('page_nav', 'bb_code_tag_code', 'bb_code_tag_php', 'bb_code_tag_html', 'bb_code_tag_quote', 'bb_code_tag_attach', 'bb_code_tag_spoiler', 'xengallery_bb_code_tag_gallery', 'thread_view', 'notice_cookies', 'oxy_news_nav_tab', 'dark_postrating', 'dark_postrating_member', 'dark_postrating_member_totals', 'message_user_info_extra', 'user_criteria_content', 'thread_list_item_icon_key', 'dark_postrating_member_notable_tabs', 'dark_postrating_account_wrapper', 'dark_postrating_navigation_visitor_tab', 'dark_postrating_visitor_panel', 'dark_postrating_member_card', 'dark_postrating_member_info', 'dark_postrating_message_user_info', 'xengallery_comments_block', 'xengallery_media_block_items', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 14, 2
Run Time: 0.000670
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 27 | Using where |
SELECT title, phrase_text
FROM xf_phrase_compiled
WHERE language_id = ?
AND title IN ('MMOCS_my_buys')
Params: 2
Run Time: 0.000078
SIMPLE | xf_phrase_compiled | const | PRIMARY | PRIMARY | 106 | const,const | 1 | |
INSERT INTO xf_bb_code_parse_cache
(content_type, content_id, parse_tree, cache_version, cache_date)
VALUES (?, ?, ?, ?, ?)
ON DUPLICATE KEY UPDATE parse_tree = VALUES(parse_tree),
cache_version = VALUES(cache_version),
cache_date = VALUES(cache_date)
Params: post, 39908, a:27:{i:0;s:216:"Русская армия получила пополнение: идущие мушкетёры и гренадёры.
12.015 Обер-офицер мушкетёрского полка. 4 детали, смола.
";i:1;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46415";}}i:2;s:99:"
12.016 Унтер-офицер мушкетёрской роты. 6 деталей, смола.
";i:3;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46416";}}i:4;s:58:"
12.017 Мушкетёр. 6 деталей, смола.
";i:5;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46417";}}i:6;s:58:"
12.018 Мушкетёр. 6 деталей, смола.
";i:7;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46418";}}i:8;s:58:"
12.019 Мушкетёр. 6 деталей, смола.
";i:9;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46419";}}i:10;s:99:"
12.020 Обер-офицер гренадёрского полка. 4 детали, смола.
";i:11;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46420";}}i:12;s:99:"
12.021 Унтер-офицер гренадёрской роты. 6 деталей, смола.
";i:13;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46421";}}i:14;s:58:"
12.022 Гренадёр. 6 деталей, смола.
";i:15;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46422";}}i:16;s:58:"
12.023 Гренадёр. 6 деталей, смола.
";i:17;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46423";}}i:18;s:58:"
12.024 Гренадёр. 6 деталей, смола.
";i:19;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"46424";}}i:20;s:182:"
Скульптор: Максим Воронин
Все фигуры есть на складе и доступны к заказам.
Наша группа "Вконтакте"- ";i:21;a:4:{s:3:"tag";s:3:"url";s:6:"option";N;s:8:"original";a:2:{i:0;s:5:"[URL]";i:1;s:6:"[/URL]";}s:8:"children";a:1:{i:0;s:34:"https://vk.com/avanpost_miniatures";}}i:22;s:66:"
Наша группа в "Facebook" (англоязычная) - ";i:23;a:4:{s:3:"tag";s:3:"url";s:6:"option";N;s:8:"original";a:2:{i:0;s:5:"[URL]";i:1;s:6:"[/URL]";}s:8:"children";a:1:{i:0;s:51:"https://www.facebook.com/groups/avanpost.miniatures";}}i:24;s:37:"
Электронная почта - ";i:25;a:4:{s:3:"tag";s:5:"email";s:6:"option";N;s:8:"original";a:2:{i:0;s:7:"[EMAIL]";i:1;s:8:"[/EMAIL]";}s:8:"children";a:1:{i:0;s:29:"avanpost.miniatures@gmail.com";}}i:26;s:53:"
Контактный телефон +7(978) 103-1812";}, 1632305603, 1714439864
Run Time: 0.006859
Params: post, 48343, a:27:{i:0;s:212:"У идущей русской пехоты появились оловянные близнецы:
- 12.015/M Обер-офицер мушкетёрского полка, 4 детали, белый металл
";i:1;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57251";}}i:2;s:116:"
- 12.016/M Унтер-офицер мушкетёрской роты, 6 деталей, белый металл
";i:3;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57252";}}i:4;s:74:"
- 12.017/M Мушкетёр, 6 деталей, белый металл
";i:5;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57253";}}i:6;s:74:"
- 12.018/M Мушкетёр, 6 деталей, белый металл
";i:7;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57254";}}i:8;s:74:"
- 12.019/M Мушкетёр, 6 деталей, белый металл
";i:9;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57255";}}i:10;s:115:"
- 12.020/M Обер-офицер гренадёрского полка, 4 детали, белый металл
";i:11;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57256";}}i:12;s:115:"
- 12.021/M Унтер-офицер гренадёрской роты, 6 деталей, белый металл
";i:13;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57257";}}i:14;s:74:"
- 12.022/M Гренадёр, 6 деталей, белый металл
";i:15;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57258";}}i:16;s:74:"
- 12.023/M Гренадёр, 6 деталей, белый металл
";i:17;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57259";}}i:18;s:74:"
- 12.024/M Гренадёр, 6 деталей, белый металл
";i:19;a:4:{s:3:"tag";s:6:"attach";s:6:"option";s:4:"full";s:8:"original";a:2:{i:0;s:13:"[ATTACH=full]";i:1;s:9:"[/ATTACH]";}s:8:"children";a:1:{i:0;s:5:"57260";}}i:20;s:209:"
Всё те же 28 мм, скульптор - Максим Воронин
Run Time: 0.003287
WHERE title IN ('notices')
AND style_id = ?
AND language_id = ?
Params: 14, 2
Run Time: 0.000162
SIMPLE | xf_template_compiled | const | PRIMARY | PRIMARY | 60 | const,const,const | 1 | |
WHERE title IN ('wf_widget_wrapper')
AND style_id = ?
AND language_id = ?
Params: 14, 2
Run Time: 0.000099
